PCM2903C: How to connect the differential output audio signal to the chip
Part Number: PCM2903C
Hi,How to connect the differential output audio signal to  PCM2903C? the sch pic is like this:
    welcome to e2e forum!
    i just wanted to clarify the question just to make sure i understand it correctly -
    Are you trying to input differential signal into the PCM2903A ADC inputs? If my understanding is wrong, can you please clarify the question? Thanks.
    Ravi
  • Hi, Ravi
    Yes, I want to input  differential signal (Left and Right  audio source) into the PCM2903C,then output signals from USB port , so I think there should be a dfferential to single-ended op amp ,is right?
    Can you recommend several chips from TI?
