TLV320AIC3254: DRC with Control
Part Number: TLV320AIC3254
Hi Team,
May I know the usage of “DRC with control” in PPS? I click the help button and find it has 3 port: in/out/control input. However, I don't know how to configure the block, such as, which port is control input? how to set the vaalue? And “DRC with control” block looks similar with “DRC” block, may I know the difference when application? thanks in advance!
  • Hi, Wiky,
    The DRC with Control block should be implemented as you mention, it is set for Stereo signals and has the connections for the input on the left side, connections for the control on the bottom side and output on the right side.
      -Diego Meléndez López
       Audio Applications Engineer
