Part Number: TPA3122D2
Hi, I'm trying to use the TPA3122D2 to drive a speaker driver in a design. To test it out I purchased components to build the example circuit given here: http://www.ti.com/lit/ug/slou214a/slou214a.pdf (P.4 Figure 3).
I built out the circuit and tried to use it to drive a small 8 ohm speaker with music from my phone, but the chip almost immediately started getting extremely hot, and the speaker only played a quiet clicking. I have checked and double checked the circuit and am certain that I wired everything correctly. I also tried building the circuit on a different breadboard with a new chip, with the same result.
Is there anything in my component choice that might be leading to this result, or any other factors I should look into?
Here is a link to the mouser cart where I purchased the components: https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=81726d98eb
Really not sure what to try at this point, any advice is appreciated.
