Other Parts Discussed in Thread: TPA2011D1
I’ve looked over the datasheet and I don’t see any mention of how to calculate the output power, and the associated output peak current of the amplifier with regards to a varying load (8 Ohms, 4 Ohms etc).
On page 4 of the datasheet there is a table that lists max output power is 400mW with a 3.3V supply and 8 Ohm load.
Is there a technical document that goes through how to calculate these values?
If not, can you please send us the equations for these calculations?
