Part Number: PCM3168A
Other Parts Discussed in Thread: PCM3168
Hi Team,
My customer is looking to use PCM3168A.
Hi Team,
Hi Joey,
PCM3168 supports two sampling modes (single rate and dual rate) in ADC operation & three sampling modes (single rate, dual rate, and quad rate) in DAC operation. The sampling mode is automatically selected according to the ratio of system clock frequency and sampling frequency by default [ex: dual rate for 256 fs and 384 fs].
So you will be able to use dual rate considering SCKI and fs rate by default. I am assuming you are referring to HW mode as in default setting.
Finally, can you please outline overall Block diagram/requirements for PCM3168 in use for this system? Thanks.
Best regards.
Ravi
