Part Number: PCM5121
Other Parts Discussed in Thread: PCM5142
Hi team
My customer is using PCM5121 in new design and they have several questions need your help.
- Are PCM5121 internal processing flow components are fixed and can't be changed by drop and drag in GED? (For example , could i modify to put the volume control modules in front of DRC modules? The ROM default setting is put the volume control behind the DRC module.)
- After processing flow configuration, how to generate the code from GDE?
Thanks in advance.
