LM4898: Output State in Shutdown Mode
Part Number: LM4898
When the LM4898 is put into shutdown mode, can I assume that the output stage is turned off and that the output enters a high-impedance state? In particular, I would like to ensure that there is no signal pass-through from input to output when shutdown is enabled.
Thank you!
Chris
  • Hi, Chris,
    Your assumption is correct, when the device enters in shutdown mode, the output is placed in high-impedance mode and there's no output signal at the speaker outputs Vo1 and Vo2.
    Please let me know if you have additional questions or comments.
    Luis Fernando Rodríguez S.
