Hello, our customer is optimizing TAS5751M parameters, some questions are popping up in our mind now.
1. On the datasheet signal flow chart shows, Pre-scale and Post-scale is in Master volume block.
Generally Pre-scaling is used for increasing headroom, it should be located front end of EQ processing block.
Where is actual location of TAS5751M Pre-scale in the signal flow?
2. Do you have document of "How to optimize Softening parameter" ?
What is difference between this and Attack time parameter?
Mochizuki
