TPA3110D2: EMI failed
Part Number: TPA3110D2
Hi TI
When we do the EMI testing.
The conduction test was failed at the three green points shown in the following figure.
Do you have any suggestions for improvement?
Thank you.
Jerry
  • hello,
    what is switching frequency select for your case? is there power supply have EMI filter design?
    Linda
  • Hi Linda,
    Switching frequency is about 300KHz. LC filters are added to the power input and TPA3110D2 output.
    Jerry
  • Hi Jerry,
    Firstly, please keep your board is good grounded with LSIN. Then please update your measurement details with us, eg. output power, PVDD, Speaker load=?ohm etc.
    Based on your report, it is strange to see that 3th harmonic is larger than primary tone @ ~300KHz. It is not reasonable on my side. Please check:
    1. please check your power board by changing another power board or adapter to see whether it is caused by different suppression capability of power board at 300KHz and 900KHz;
    2. Tuning your EMI filter by adjust inductor and cap to see whether it can be lowered ;
    3. Please check our inductor to see whether it is saturation that cause this.
    Alix Wan
