Part Number: PCM2706C
Tool/software: Linux
Hi team.
I have confirmed that the PCM2706C datasheet does not require a dedicated device driver.
Does it support both Window or Linux OS?
Please explain why you do not need a driver.
Thank you
Hi team.
Thank you
Hi Jeon,
The device was designed to comply with a standard windows driver for USB audio. I believe there is a similar driver on Linux that the device is also compliant with, so it does not require a specialized driver either.
You should be able to find some examples on through the open-source community.
Paul
