TAS5805M: I would like to test fault line of TAS5805 In prospective of software integrity check
Part Number: TAS5805M
Hi ,
Can you suggest a way to force trigger fault interrupt ? I would like to confirm our driver handles recovery in case of fault. For example setting certain limits to lower than what is expected through configuration registers.
Thanks in advance.
  • hello,
      you can create CLK error (like I2S CLK bus anything interrupt) to monitor system handling recover. Same for OC, OT etc.
    for OC, you can create output terminal (after LC filter) short to GND or Short to Power.
    regards
    Linda
