TLV320AIC3263: Design help needed
Part Number: TLV320AIC3263
Our design consists of 2 digital and 1 analog interfaces (all bidirect). We want to connect any left input channel to any left output channel and any right input channel to any right output channel.
It must be also possible to mix all left input signals together and route them to any number of left outputs. e.g. analog left input together with digital ASI1 left input and route the mixed signal to the left ASI3 output and to the left analog output.
We have a problem with the constellation with one ASI1 left input signal that should be routed to the left ASI3 output and at the same time to the left analog output. We can see & hear the signal on the analog left output, but we have no data on ASI3 output. The frame clocks WCLK and BCLK are available on ASI3 interface. Both ASI interfaces works as master.
In the attachment you will find the PurePath studio project.
Please help me to solve our problem
Thank you
Best regards
Waldemar
TLV320AIC3263-Design.zip
