Other Parts Discussed in Thread: PCM5252, PCM3070, TLV320ADC3101, PCM1804, TPA3255
Hi, I am trying to validate a design using several PurePath ICs. To be sure of what is a valid configuration and to further investigate the possibilities I would like to use the PurePath Studio software. However each time I make a request for export access I am refused. Unfortunately the people dealing with the cases do not seem to help me. I have no clear explanation about what is causing the export request to be refused. Furthermore customer support seem unable to help.
I apologise for using the forum for this type of question, however I find no explanation about what information is required, or for that matter what part of my information is causing the problem.
Currently I either decide against using PurePath prodcuts, or I will be forced to program them manually. Which will not be straightforward. It also means that I will not be aware of any configuration limitations until the point at which I start bit bashing the ICs.
Any help to explain how I might proceed would be much appreciated.
All the best
Aidan
