Other Parts Discussed in Thread: PCM5100A, PCM5122
Dear team,
Could you please tell me what is the charge pump's frequency? I didn't fine it in the datasheet.
Thanks & Best Regards,
Sherry
Dear team,
Sherry
Hi Paul,
Is there a function to charge pumps' frequency? What is the relationship between charge pumps' frequency and LRCK?
Sherry
The charge pump can only be configured manually in the devices that have an SPI/I2C interface, such as the PCM512x/4x devices. The PCM5100A will auto-detect the LRCK/SCK ratio, and configure the clock tree to get the best case values for the charge pump.
If you take a look at table 132 of the PCM5122 datasheet, you will see examples of the clock tree values, resulting in a charge pump frequency of either 1411.2kHz or 1536kHz, depending on if the LRCK is a 44.1kHz based clock or a 48kHz based clock (respectively).
Paul
