Hi Sirs,
Sorry to bother you.
Our schematic as below.
When the Win10 logo appears before entering the OS, we found speaker had bo noise and looks is caused by AMP to be enable. How can I improve this problem?
Thank you
Hi Sirs,
Thank you
Hi Lin,
I would recommend to use the same component values for both IN+ and IN-, the schematic shows different resistor and capacitor values on each of them.
Using single-ended input makes the device more susceptible to pop noise. This noise is caused by mismatch in the input capacitors charge/discharge. If you use different values on each part of the input, you may be even increasing this mismatch.
Some recommendations to reduce pop noise are:
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Sirs,
Thanks for your reply.
Actually Single-ended inputs this section cannot be modified.
The capacitor resistors already use X7R and 1% precision resistors.
So is there any more advice or design guide?
Now my approach is use realtek to modify the FW into the OS.
Let EAPD pull high to open AMP, but there are other side effects.
Thanks!!
Hi Sirs,
Lin,
Is there a chance you can take some scope captures of the inputs during the pop transient?
Perhaps you can check the difference between the input pair and adjust input capacitors independently to reduce the difference during the transient.
-Ivan Salazar
Hi Lin,
Do you have further questions or comments about the last post?
-Ivan Salazar
