Part Number: TAS2557
customer reported following 2 questions on TAS2557
- What makes the actual excursion is far lower than speaker box spec?
- What makes enable the “phase shift” will make the excursion getting smaller
Hi Peter,
Could you please send their PPC3 file and the test audio file is possible?
I'll check the possible reasons for this. I wonder why the estimated excursion is low as well. Have they tried different audio files?
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan,
I am attaching the PPC3 file and test audio file for your review.
Thanks for supporting to check the excursion issue.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/6/test_5F00_file.7z
Hi Peter,
I'm currently checking this out.
Can you try to configure the device in ROM Mode 1 instead of using the snapshots? You can also try by enabling the FeedForward Protection in the SmartAmp panel.
I want to verify if this could be caused due to the signal classifier. This feature is only present in smartamp mode with feedback enabled.
-Ivan Salazar
