PurePath Wireless Configurator- CC Debugger "disconnect"- problem
I tried to program my PPW ew board with CC Debugger ,but my PPW Configurator is allways in disconnected state.  I downloaded a SmartRF Studio 7 for CC debugger drivers. PPW Configurator see the debugger but in disconnected state. I did resetting the debugger, load the drivers another time, change the version of PPW Configurator v1.0.1 , v1.0.2, v1.2.3  but it didn't work.
Board is working with its config. inside , streaming audio , and constructing an audio network. Everything is OK with its configurtion which programmed earlier with  another man, but I didn't program it.
  1. What cables do I plug while programming my board . USB power cable + debugger cable , or only the debugger cable. Because with this two cable U7 regulator runs hot.   I tried to program only plugging the CC deugger . Is it true?
  2. My CC Debugger firmware version is 14 . I used PurePath Wireless v1.0.2.  Is that combination incoordinate? Where I change my CC debugger firmware? I didn't see anywhere.
