Other Parts Discussed in Thread: TLV320AIC23B
I have problems with the TLV320AIC23B.
My digital output does not seem to produce correct audio samples. It is somehow arbitrary. I give a 1 kHz signal as an input. While the i2s is correct, meaning that the CLK, LRCOUT and DATA are correct with their timing, my DATA seems to be wrong.
When I measured the VMID voltage, in one chip, I found it to be almost zero, in another chip, almost as high as the AVDD and in another one, a little less than AVDD/2.
I assume that my board somehow "burns" the IC, but I have check everything, it is just the power supply and the input filter.
Can anyone suggests how is it possible to damage the chip in order to make the VMID not to work? Thanks.
