Kindly review and give feedback on the below analog audio interface conections to TLV320AIC3106 required for an IP Phone design:
-Thariq C P
-Thariq C P
Hi Thariq,
The connections look good to me. The TLV320AIC3106 is a good option for IP Phone design as the device inputs/outputs are very flexible in terms of routing.
Aaron
Hi Aaron,
The speakers we use are mono. I hope there is no issue in connecting two independent speakers to LEFT & RIGHT outputs.
Also the amplifier used is stereo (taken from Application Circuit in AIC3106 datasheet). Could you please suggest a suitable mono option?
Thariq
Hello Thariq,
That should not be an issue.
As for the amplifier, you can always try and use our quick search for suitable parts. You may enter the parameters that fit your application. Unfortunately, I am not familiar with our audio speaker amplifiers so you can always post a different question regarding speaker amps.
Aaron
