Part Number: TAS2559
Hi all,
We want to test TAS2559EVM with external I2S source. Here're some questions:
1. In ROM-Mode 1, is TAS2559 worked as I2S master mode? can we change the setting to slave mode by I2C register rewrite? How to do it?
2. For 48KHz/I2S input/ 16bit data length source from ASI1 input, would you please helping to provide a sample cfg for reference first? We'll use learning board to fine tune the speaker in the next step. Or, I can use learning board to build up a simple cfg first?
Thanks for your kindly help.
Gary Teng
BTW, I dump ROM-mode 1 register setting as cfg file. FYI. It's master mode now...
