TPA3255: TPA3255 POP noise
Other Parts Discussed in Thread: TPA3255
Dear,
How to avoide the POP noise of TPA3255 because  TPA3255 have no Mute/SD PIN. Our customer is going to use TPA3255 for his new design and found that it has no standby/mute pin. Could you provide some advice? Thank you very much.
Best regards
Kailyn
  • Hi Kailyn,
    For the start-up, it has a Cstart pin functioning as a soft-start pin to keep balance between the OUTP/N to avoid pop noise.
    For power down, it is recommended to hold RESET# pin logic low, and then a controlled ramp down sequence would be executed to avoid the audible noise.
    Hao
