LM48560: Amplifier output
Part Number: LM48560
Hi TI,
Can you tell me the advantages and disadvantages of having an output voltage offset in the piezo position?
  • Hi Mason,
    We'll take a look at your questions and reply as soon as possible.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
  • Mason,
    Could you provide more information about your question?
    Do you need output offset? Have you used other drivers with offset at the output?
    When a load is connected in differential mode, like this case, any offset that is present at both sides of the connection (common-mode) is suppressed. If you need offset voltage in a differential load, you would need to induce the offset only on one side of the output pair. This is not common since most drivers are Class-D.
    -Ivan Salazar
  • Mason,
    Do you have further comments about the information above?
    -Ivan Salazar
