Hi sir
I have a tpa3116d2 amplifier, I think 50*2 isn't coming properly but 100 coming good. First I m use 12v and then 24v but 50*2 same in 24v but 100 perfect, what's wrong in 50*2?
Please help me.
Hi sir
Please help me.
Hello customer,
Please provide more spec about your design, like load=? ohm?
You can use input level to control output power under certain PVDD. eg. 4ohm load: sqrt(50*4*2)=20V (from Vrms^2/R=50W), which needs PVDD>=20V to achieve no clipping 2*50W@4ohm.
I would suggest to provide us with information above as well as the schematic and waveforms indicating your issue.
Alix Wan.
Hi Shipu,
Did you check the input signal, Fault pin, output signal on 50W*2 case?
Derek
