Part Number: PCM5101A
Hi teams
We have several questions about PCM510XA that need your help to figure it out.
- Compare to a device with 1Vrms maximum output voltage (SNR is 106dB). PCM5101A (2.1Vrms maximum output with 106dB). If we need to compare the parameters with a device with 1Vrms the actual SNR of PCM5101A should be 106dB-6dB? Am my calculation is right?
- If the reset pin of PCM5101A is low. Not matter the I2S come first than AVDD/PVDD or not won't influence the DAC?
