TAS2770: Noisy Output
Part Number: TAS2770
Hi
We are using TAS2770, which producing a noisy output (audio) even the SBCLK, FSYNC and SDIN are fine.
How to find whether the problem is due to hardware or software?
Anjanaa
  • Hi, Anjanaa,
    Our team will take a look at this issue and will answer as soon as possible.
    In the meantime, could you provide details about your circuit schematic and registers configuration, please? This would be useful to get a better approach to this issue.
    Thank you.
    Luis Fernando Rodríguez S.
  • Hi Anjanaa,
    Can you share your SBCLK and FSYNC frequencies as well as SDIN data format? (word and slot length, offset bits, etc)
    Can you share your register configuration? If you have PPC3 file it would be good as well.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
  • Anjanaa,
    Are you able to get good audio output from TAS2770?
    If not, can you share the information requested above?
    Thanks and Best regards,
    -Ivan Salazar
