Hi team,
My customer would like to confirm the power sequence of TAS5717. Because there is some sequence problem for other audio product in different mass production product.
They need to confirm the power sequence whether it will induce the pop-noise, burn out and other possibility issue if
they didn't follow the recommendation power sequence at our datasheet.
The suggestion of power sequence of datasheet is as below figure. But, their system design sequence is as below link. It is a little difference with our suggestion.
They would like to confirm with you whether there is any concern from our product line. Will it induce any other possibility abnormal behavior?
The detail measurement is as below link. Thank for your kindly help.
