Hello expert,
I have several questions for TPA3128D2.
First, could you provide TPA3128D2 gain setting formula regarding R1 and R2? Because datasheet is only explained about the gain setting under 20dB, 26dB, 32dB and 36dB. But my customer would like to adjust the gain more precisely(e.g. 23db).
Next, Would you explain about why datasheet has the THD+N characteristic under 6kHz? I guess this situation will tend to cause the worse THD+N performance due to this devices design. So you indicated the THD+N performance under 6kHz.
Last, How many TPA3128D2's Sync Pin could we connect in parallel? This point is not on datasheet and typical application is only using 2pcs TPA3128D2. So we'd like to know about the maximum value of sync pin connection in parallel.
I'm looking forward to hearing back from you.
Kazuki Kuramochi
