TPA3138D2: SD/FAULT pin and Mute time
Part Number: TPA3138D2
Hello
 Can you correct my understanding for following items?
1. SD/FAULT pin ,
   Must be tied to PULL-UP register?
  Register value( 4.7K-500K) can be defined based on MCU's drive performance.  Is it correct?
2. Mute time.
    SD/Fault pin is changed from Low to High.
    Mute lease time is tON( Typical 50ms ).   is it correct?
