Part Number: DRV134
I am using a DRV134 in a circuit as a replacement for a SSM2142. The board is already built using 0.1uF capacitors to bypass the power supply. The DRV134 datasheet calls for 1uF capacitors.
Will the 0.1uF capacitors be a be acceptable or should I replace them with 1uF caps?
