The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TAS2770EVM: Pure Path Console system diagnostics failing?
Part Number: TAS2770EVM
Other Parts Discussed in Thread: TAS2770, TAS2557
Team,
I am using the TAS2770EVM for my testing. I installed the PPC 3 and could successfully connect to the EVM, however the system diagnostics tests are failing and I wanted to request your help with this.
See screenshot below:
I am wondering if PPC3 software is compatible with this EVM as I can only see TAS2557 listed under the EVM apps and not TAS2770.  Please advise if something is not correct with this?
I am also not able to playback audio with the below settings. The default selected is audio TI USB Audio UAC2.0 .See screenshot below.
