Hi Collin,
I am developing a project, for which I need to process two 16 slot-TDM streams (24bit per slot).
I need to make a 2 channel mix from those 32 slots, which I then will send to an Bluetooth or IOT device.
I have read almost every possible datasheet on Ti's site, but I still cannot find the solution without using some overkill multimedia DSP.
The closest approach is the tlv320aic3268 codec, but even here I am not really sure it would work.
Could you help me to find a solution? Thank you in advance!
Best regards from Germany,
Gustavo
