Part Number: LM386
Does LM368 require an initial calibration or does it have a procedure to follow for the first measurement? or is it ready to be used for the first time?
Thank you
Part Number: LM386
Thank you
Hi, Lakhal,
The LM386 does not require an initial calibration. I would just recommend to ensure that the Bypass pin have the 10uF capacitor as close as possible to the pin and Vs is completely stable and there's no ripple when using the device. This device is sensitive to voltage changes on these pins.
Please let me know if you have additional questions or comments.
Luis Fernando Rodríguez S.
Hello Luis,
Thank you for your clear answer,
Can you tell me please if the PINS connection is OK? Thank you
Hi, Lakhal,
Could you share again the picture? For some reason it was not attached correctly. You can click on the Insert/Edit Media button to place it on you post.
Thank you.
Hi, Lakhal,
I apologize for my late response. For some reason I didn't get the notification of your answer.
The schematic seems to be all in order. I didn't find anything that should be modified.
