Part Number: SRC4382
Hi Team,
My customer designed the schematic following to the below figure from datasheet. However, it was found that the sampling rate of 192k Hz was not decoded. But if 0.1uF capacitor of TR- was changed to 1uF, it can be decoded for the 192kHz signal. Now we need your help to confirm the following two points:
1. What is the use of this capacitor?
2. Will there be other problems when changing to 1uf capacitor?
Thanks!
