TPA6140A2: Using only right channel (INR– & INR+)
Part Number: TPA6140A2
Hi team,
I would like to confirm if it is okay to leave the pins of INL– & INL+ (Left channel) floating as the customer would like to use only the Right channel of TPA6140A2?
Thanks!
Jonathan
  • Hi Jonathan,
    It is OK to leave these pins open if not used. Other option would be to AC couple them to GND.
    You should also make sure that HP_EN_L bit is set to 0 so that amplifier is disabled and not consuming idle curent.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
