Driver for tlv320aic32
Anonymous
Anonymous
Other Parts Discussed in Thread: TLV320AIC32, TLV320AIC33
     I am working on a dm6446 board..It has tlv320aic32 on it.
But the kernel sources i got with the EVM contains drivers fot tlv320aic33.
Do the drivers for tlv320aic33 work for tlv320aic32?
i ma getting a I2C error.
Where can i find the tlv320aic32 drivers for my board? my EVM is dm6446.
Thanks in advance.
  • The AIC32 and the AIC33 are register compatible for the most part. The AIC33 has differential inputs vs. the AIC32 has single ended inputs. One other major difference is that the AIC33 has a programmable I2C address, whereas the AIC32 is fixed at 0011000 so this could be the issue.
    A link to many drivers for the CODEC's is here:
    http://focus.ti.com/docs/toolsw/folders/print/codecdrivers-sw.html
    Many of the specific drivers for DSP EVM's are handled by the specific processor team so you can also check with the DM6446 team to see what they have.
  • Anonymous
    0 Anonymous in reply to Converter Apps
    Thanks for your kind reply.
    The link which you gave: http://e2e.ti.com/support/data_converters/audio_converters/f/64/t/266169.aspx
    doesn't specific  tlv320aic32 driver for DM6446 or Davinci.
    Can you suggest why is it so?
    And regarding the specific drivers, i couldn't find the specific processor team info.
    Is it on TI website only.
    I'm attaching a booting sequence log so that you can have a look into the error.
    Please reply.
    Thanks in advance
    Booting Sequence:
    TirDavinci_EVM# printenv
    bootdelay=3
    baudrate=115200
    ethaddr=ff:ff:ff:ff:ff:ff
    nfshost=10.42.43.1
    serverip=10.42.43.1
    bootfile=uImage
    ipaddr=10.42.43.10
    rootpath=/home/chetanpatil/workdir/filesys
    bootargs=video=davincifb:vid0=0,0:vid1=0,0 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=NTSC console=ttyS0,115200n8 noinitrd rw ip=10.42M
    stdin=serial
    stdout=serial
    stderr=serial
    bootcmd=tftp 0x80700000 uImage ;bootm 0x80700000
    Environment size: 522/8188 bytes
    TirDavinci_EVM# saveenv
    Saving Environment to Flash...
    Un-Protected 1 sectors
    Erasing Flash...
    Erasing sector  3 ... done.
     Erase Operation Completed.
    Erased 1 sectors
    Writing to Flash...-done
    Protected 1 sectors
    TirDavinci_EVM# boot
    TFTP from server 10.42.43.1; our IP address is 10.42.43.10
    Filename 'uImage'.
    Load address: 0x80700000
    Loading: #################################################################
    done
    Bytes transferred = 1574800 (180790 hex)
    ## Booting image at 80700000 ...
       Image Name:   Linux-2.6.10_mvl401
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    1574736 Bytes =  1.5 MB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
    OK
    Starting Davinci linux kernel...
    Uncompressing Linux......................................................................................................... done, booting thee
        Linux versio1
    CPU: ARM926EJ-Sid(wb) [41069265] revision 5 (ARMv5TEJ)
    CPU0: D VIVT write-back cache
    CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
    CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
    Machine: DaVinci EVM
    Memory policy: ECC disabled, Data cache writeback
    DM6443
    Built 1 zonelists
    Kernel command line: video=davincifb:vid0=0,0:vid1=0,0 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=NTSC console=ttyS0,115200n8 noinitrdM
    PID hash table entries: 512 (order: 9, 8192 bytes)
    Console: colour dummy device 80x30
    Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Memory: 120MB = 120MB total
    Memory: 118272KB available (2720K code, 551K data, 184K init)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    CPU: Testing write buffer coherency: ok
    spawn_desched_task(00000000)
    desched cpu_callback 3/00000000
    ksoftirqd started up.
    desched cpu_callback 2/00000000
    desched thread 0 started up.
    NET: Registered protocol family 16
    DaVinci: 71 gpio irqs
    Registering platform device 'serial8250.0'. Parent at platform
    Registering platform device 'musb_hdrc'. Parent at platform
    Registering platform device 'mmc.0'. Parent at platform
    DaVinci I2C DEBUG: 02:05:54 Feb  3 2011
    Registering platform device 'i2c'. Parent at platform
    ch0 default output "COMPOSITE", mode "NTSC"
    MUX: initialized LOEEN
    MUX: initialized LFLDEN
    VPBE Encoder Initialized
    LogicPD encoder initialized
    SCSI subsystem initialized
    usbcore: registered new driver usbfs
    usbcore: registered new driver hub
    musb_hdrc: version 2.2a/db-0.4.8 [cppi-dma] [host] [debug=0]
    musb_hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
    musb_hdrc: MHDRC RTL version 1.300
    musb_hdrc: USB Host mode controller at c8002000 using DMA, IRQ 12
    musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    DaVinci I2C WARNING: i2c: NACK detected
    MUX: initialized MCBSP0
    JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
    yaffs Feb  3 2011 02:05:34 Installing.
    Registering platform device 'davincifb.0'. Parent at platform
    davincifb davincifb.0: dm_osd0_fb: 720x480x16@0,0 with framebuffer size 675KB
    davincifb davincifb.0: dm_osd1_fb: 720x480x4@0,0 with framebuffer size 675KB
    watchdog: TI DaVinci Watchdog Timer: timer margin 64 sec
    Registering platform device 'davinci_resizer.2'. Parent at platform
    Registering platform device 'davinci_previewer.2'. Parent at platform
    Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
    Registering platform device 'serial8250'. Parent at platform
    ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
    io scheduler noop registered
    io scheduler anticipatory registered
    RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
    loop: loaded (max 8 devices)
    Registering platform device 'ti_davinci_emac'. Parent at platform
    TI DaVinci EMAC: MAC address is deadbeaf
    TI DaVinci EMAC Linux version updated 5.0
    TI DaVinci EMAC: Installed 1 instances.
    netconsole: not configured, aborting
    i2c /dev entries driver
    Linux video capture interface: v1.00
    Registering platform device 'vpfe.1'. Parent at platform
    vpfe vpfe.1: DaVinci v4l2 capture driver V1.0 loaded
    Registering platform device 'DavinciDisplay.1'. Parent at platform
    Trying to register davinci display video device.
    layer=c70ef800,layer->video_dev=c70ef964
    layer=c70ef600,layer->video_dev=c70ef764
    davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
     Davici AEW Driver cannot be loaded
     VIDEO PORT is not enabledData Flow path from CCDC is disabled
     Davinci AF driver cannot be loaded
     CCDC needs to be configured<6>Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
    ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
    MUX: initialized HDIREN
    MUX: initialized ATAEN
    Palm Chip BK3710 IDE Register Fail
    elevator: using anticipatory as default io scheduler
    drivers/usb/class/bluetty.c: USB Bluetooth support registered
    usbcore: registered new driver bluetty
    drivers/usb/class/bluetty.c: USB Bluetooth tty driver v0.13
    Initializing USB Mass Storage driver...
    usbcore: registered new driver usb-storage
    USB Mass Storage support registered.
    usbcore: registered new driver usbhid
    drivers/usb/input/hid-core.c: v2.0:USB HID core driver
    mice: PS/2 mouse device common for all mice
    mmc mmc.0: Supporting 4-bit mode
    mmc mmc.0: Using DMA mode
    Registering platform device 'davinci-audio.0'. Parent at platform
    i2c write: error = -121
    tlv320aic33_write_value: aic33 write failed
    aic33 write failed for reg = 0
    aic33 write failed for reg = 42
    aic33 write failed for reg = 51
    aic33 write failed for reg = 65
    aic33 write failed for reg = 86
    aic33 write failed for reg = 93
    aic33 write failed for reg = 37
    mmcblk0: mmc0:aaaa SD02G 1931264KiB
     mmcblk0:<4>DaVinci I2C WARNING: i2c: NACK detected
     p1
    aic33 write failed for reg = 15
    aic33 write failed for reg = 16
    aic33 write failed for reg = 47
    aic33 write failed for reg = 64
    aic33 write failed for reg = 82
    aic33 write failed for reg = 92
    aic33 write failed for reg = 19
    aic33 write failed for reg = 22
    aic33 write failed for reg = 17
    aic33 write failed for reg = 18
    aic33 write failed for reg = 26
    aic33 write failed for reg = 27
    aic33 write failed for reg = 28
    aic33 write failed for reg = 29
    aic33 write failed for reg = 30
    aic33 write failed for reg = 31
    aic33 write failed for reg = 43
    aic33 write failed for reg = 44
    aic33 write failed for reg = 25
    NET: Registered protocol family 2
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 8192 bind 16384)
    NET: Registered protocol family 10
    IPv6 over IPv4 tunneling driver
    NET: Registered protocol family 17
    IP-Config: Complete:
          device=eth0, addr=10.42.43.10, mask=255.255.255.0, gw=255.255.255.255,
         host=10.42.43.10, domain=, nis-domain=(none),
         bootserver=255.255.255.255, rootserver=10.42.43.1, rootpath=
    Looking up port of RPC 100003/2 on 10.42.43.1
    Looking up port of RPC 100005/1 on 10.42.43.1
    VFS: Mounted root (nfs filesystem).
    Freeing init memory: 184K
    INIT: version 2.85 booting
    Mounting a tmpfs over /dev...done.
    Creating initial device nodes...done.
    Activating swap...done.
    Remounting root filesystem...done.
    Calculating module dependencies
    Loading modules:
    Checking all file systems: fsck
    fsck 1.35 (28-Feb-2004)
    Mounting local filesystems: mount nothing was mounted
    Cleaning: /tmp /var/lock /var/run done.
    Setting up networking (ifupdown) ..
    Cleaning: /etc/network/run/ifstate done.
    Starting network interfaces: done.
    Starting hotplug subsystem:
       pci
       pci      [success]
       usb
    kobject_register failed for usbcore (-17)
       usb      [success]
       isapnp
       isapnp   [success]
       ide
       ide      [success]
       input
       input    [success]
       scsi
       scsi     [success]
    done.
    Starting portmap daemon: portmap.
    done.
    Setting pseudo-terminal access permissions...done.
    Updating /etc/motd...done.
    INIT: Entering runlevel: 3
    Starting NFS common utilities: statd lockd.
    Starting internet superserver: inetd.
    Starting MontaVista target tools daemon: mvltdmvltd version 2.1 MontaVista Software,Inc.
    mvltd[1026]: can't send broadcast message: Network is unreachable
    mvltd[1027]: started on port 34577
    MontaVista(R) Linux(R) Professional Edition 4.0.1 (0600980)
    10.42.43.10 login: root
    Last login: Sun Feb  1 03:24:56 2004 on console
    Linux 10.42.43.10 2.6.10_mvl401 #1 Thu Feb 3 02:07:36 IST 2011 armv5tejl GNU/Linux
    Welcome to MontaVista(R) Linux(R) Professional Edition 4.0.1 (0600980).
    root@10.42.43.10:~#
