Part Number: PCM1803A
Other Parts Discussed in Thread: PCM1795, PCM1808, PCM1807
The power-on-reset sequence is mentioned on page 10 of PCM1803A data sheet as follows. However, it isn't mentioned the relationship between VCC and VDD at power-on and power-off.
So, could you please tell me the recommended power on/off sequence for VCC and VDD?
Additionally, it isn't mentioned about /PDWN which is power-down control pin in figure 17. Could you please tell me the recommneded power on/off sequence as well if using /PDWN pin ?
Please see the related threads as follows.
PCM1803A: Power Supply Requirement
https://e2e.ti.com/support/audio/f/6/t/736015
PCM1795, PCM1808 / Power up sequence
https://e2e.ti.com/support/audio/f/6/t/251395
Kato
