I am using the mute function on the TPA3132D2RHBT IC to modulate a signal. When the Mute Signal is disabled/enabled, it looks like the audio amp has a soft start up/turn off that does not cause the signal to saturate. If i used the SDZ pin instead of the Mute pin, would this help?
