Basically I would like to generate chirp audio signal that sweeps from 16Khz to 18Khz. I want to use a micro controller to generate such chirp signal as the control signal, an external hardware connecting to the micro controller which converts the control signal to the corresponding chirp sound wave.
Essentially the external hardware should be able to be controlled by the micro controller and generate customized audio signals.
Does TI have such products can serve as the external hardware?
TIA!
