Other Parts Discussed in Thread: LM124
We are considering the use of this USB-Codec for an audio head-set application and would like to obtain further details and advice such as :
What is the Production Life Cycle of the PCM2912A ? Approximately for how much longer will this part be available and in full production and not NRND ? We would like to know the state of the PCM2912A as it is a relatively old part already and require at least 5 -7 years of usability without obsolescence ...
We intend to interface this part to an Android OS and would like to know what it will be default device class, and specifically so, the USB audio class specification ? Class UAC1 or UAC2 or both ?
Even though the name mentions PCM, the data-sheet does not make any reference to the actual audio format. Is the audio format PCM ? Sorry if this is a silly question ?
The PCM2912A play-back output is stereo L & R, but can the output be configured specifically for pure differential mono instead, or made so that the L & R are directly out of phase outputs ??
Similarly can the PCM2912A input be configured for pure differential mono input ?
Thank you in advance for your advice.
Mike
