Part Number: TPA6133A2
Other Parts Discussed in Thread: PCM2912A
I would like confirmation that this part will work with a 5v single-rail supply and a 150-5150 ohm, ground referenced, mono headset. I am using a PCM2912A headphone output as the TPA6133A2 input.
Should I float the HGND from the PCM2912A and consider it a differential input to TPA6133A2?
Do I still need the DC blocking caps on the input?
What is the best way to terminate the unused channel?
I will not be using the shutdown mode, but is it advisable to put a cap on the ~SD input to give the power time to stabilize and reduce start-up pop?
Thanks.
