Part Number: PCM3168A
The power dissipation when ADC and DAC are used at the same time with fs=48kHz is 1160 mW (typ.) according to the datasheet, correct?
Kazuto
Kazuto
Yes, you are correct and when the all of the DAC and ADC channels are active at 48kHz sampling rates, the power dissipation is typically 1160mW with a high-side maximum of 1480mW. Most units will operate well away from the maximum value.
