Other Parts Discussed in Thread: PCM5242, TINA-TI
I'd like to use ina1650 to receive differential signal from pcm5242 and convert it single ended output. I am using the schematic provided in Fig58 of the datasheet.
Instead of XLR connectors I plan to get a signal directly from pcm5242 output.
Do I need AC-coupling capacitors (C1-C4) in this case?
And if yes, what\s the optimal TYPE of the capacitors? I am choosing between smd ceramic and TH bipolar electolytes
