Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TLV320AIC1110: tlv320aic1110 DTMF routing
Part Number: TLV320AIC1110
Page 29 of the datasheet states "Tones from the DTMF generator block are present at all outputs and are controlled by enabling or disabling the individual output ports."  However the block diagram on page 5 shows the DTMF output being injected downstream of the PCMOUT.
Will the DTMF tones be present on the PCM output also? I need to send it back through the POTS circuit that is on the PCM interface.
