Part Number: PCM1860-Q1
please tell me about power sequencing
1. When should the IOVDD be at start up? Is it ok to apply same time as DVDD and AVDD?
2. regarding to Figure 71. Separate 3.3 V for AVDD and DVDD, customer will have some cap on each pins, which makes slight difference in rise time, and DVDD/IOVDD comes earlier than AVDD. Is there any issue? is it possible to cause leakage current from supply to supply?
3. what is recommended shut down sequence? there will be slight time difference between DVDD/IOVDD and AVDD same reason as #2. Is there any issue?
4. what is required power cycle interval? (on-off interval)
