Part Number: PCM6340-Q1
Hi team,
Could you explain the feature of TX_LSB register in 0x08 and the guideline of how to configure it?
In my setting, MSB first and TX_OFFSET = 1d.
regards,
Hi team,
regards,
Hi Shinji-san,
Typically you should not need to change this setting but it just controls how early the device will release the data line after the transmission of the LSB (last bit sent). This just gives more flexibility when the bus is shared with other devices for when another device can assume control of the data line.
Zak
