Hi ti Team,
I encountered a problem while debugging TAS2560,The current phenomenon is that there is no sound. Can you provide me with the basic CODE?
Hi, Smith,
Our team will take a look at this request. In the meantime, could you provide the code that you are using to debug the TAS2560? Are you using one of our evaluation modules?
Luis Fernando Rodríguez S.
Hi Smith,
Are you using our EVM or a custom board?
You can get the device configuration file from End System Integration panel. This provides a set of options you can adjust based on your system requirements. If you're using the EVM, you can use the default values.
You can get the configuration file either in cfg or header format:
If you're looking for the driver itself, you can find it in our repository:
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Smith,
Do you have any further questions on this topic?
Please let us know if your questions are solved so we can close this thread.
Thanks!
-Ivan Salazar
