Part Number: TAS5634
Hi all,
I have a question for you.
TAS5634DDV is sourced by 60 V. 1 kHz output signal. When voltage on output signal is above 90 V, then amplifier started clipping.
It means, that signal is over 1 % THD and that is the reason, why started clipping?
Or is it only information, that amplifier may be damaged?
Thank you for the answer.
Vojta
