Part Number: TLV320ADC3140
I post the same question as to the related thread.
How much is Input common-mode DC full-scale range in DC coupled input mode?
Does it depend on VREF setting?
Kuramochi
Kuramochi
Hi Kuramochi-san,
The input common-mode should be set to accommodate the expected input signal swing so that the max signal level + common-mode bias does not exceed the ADC input range. The device itself will bias the inputs to ~1.48V internally to support 2Vrms differential input with VREF = 2.75V. The input common-mode bias does change if the VREF settings is changed though. For reference, changing VREF to 2.5V moves the input bas down to ~1.35V. The input is biased slightly higher than 1/2*VREF to allow for some margin since the input PGA cannot swing all the way to GND. I hope this helps!
Zak
