Other Parts Discussed in Thread: TAS2563
Hi Liu,
After review of the schematic, I have some comments:
Please let us know if you have any questions.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Switch,
This warning message can be ignored, but could you please explain what is the procedure you follow to test the device?
If you can also share a picture of your hardware setup it would also help to make sure everything is setup correctly.
A procedure you can follow is:
-Ivan Salazar
Hi, Switch,
Thank you for providing the EVM pictures. Our team will take a look at them and provide additional details and suggestions to make it work properly.
Luis Fernando Rodríguez S.
Please try checking the IRQ flags of the device while you try to play audio. The process is as follows:
Play an audio file for a little bit and see if any of these flags trigger.
Let me know the result of this.
Thank you,
Justin Beigel
Thank you for the screenshot. I will look into this and get back to you tomorrow.
Justin Beigel
To help debug this, can you take an oscilloscope capture of VBAT as you power on the EVM? Also, what happens if you try using the second device on the EVM?
Additionally, this shouldn't have an impact but, you can remove the +/-15V supply to the board. You only need to do this if you are using the differential to single ended filter while doing a THD+N measurement.
Justin Beigel
