Part Number: PCM5102A
Hello Expert,
I'd like to know about detailed behavior of PCM5102A regarding I2S clock halting.
First, they want to know how long does PCM5102A take time for finishing output ramp up.
We plan to unmute by XSMT pin 4ms after I2S signal is started to supply.
I think it take 4ms + 104samples to finish ramping up and output expected signal.
Is this understanding correct?
Second, I'd like to know about the pop noise concern under First question's situation.
I checked several thread on E2E which explained there is possibility to cause pop noise by releasing analog mute.
Then, I'd like to know about there is possibility to happen pop noise under first question's situation.
Would you tell me about whether there is possibility to happen pop noise under first situation?
Last, I'd like to know about the concern when happened I2S clock halt.
Is there any concern when I2S's MCLK/BCLK/LRCK is halted simultaneously?
I'm looking forward to hearing back from you.
Kazuki Kuramochi
